Yes, it's the IAC.
Sometimes cleanable, sometimes not.
Car should start and if cold, idle high at maybe 1000-1200 rpm for a minute or three
Hardest part of changing the IAC is that you need a huge (#0 ?) Phillips screwdriver, and
some of those stupid screws still won't come unless you give them a nice tap.
EDIT: Just read the thread from Lexus.
The OP there has an error. There is a gasket on the IAC that needs to be either replaced, or,
use the old gasket and add some gasket glue; otherwise you may get an air leak you don't want.
Also, one fellow mentions using vise grips on the screwdriver.
A nice adjustable wrench fitted onto the handle does a better job of giving you leverage.
One Tequila, Two Tequila,Three Tequila...Floor
.Gen 3 - 2005 Touring Black on Black
.2nd Toy: BMW 328ic Convertible
Reason: Detail
