Is $1100 too much to replace a timing belt? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 08-06-2009, 01:23 PM   #1 (permalink)
View 2002AvalonGuy's Photo Gallery
New to these forums. I'm a college student, of obvious low financial means, and just took my car to the dealer for a check-up as it hasn't been in for probably 2 years. I have an 02 Avalon that has 135K miles on it. They recommended I change the timing belt as it has never been done before, and want $1100 for parts and labor. This is for the "kit" which includes the water pump and other stuff.
Question is: would I be paying too much, or is this right? It seems from reading this forum and others that they are charging me way too much, and that I should be able to get it for about $600-800. I appreciate any advice you guys can give me.
2002AvalonGuy is offline   Reply With Quote
Old 08-06-2009, 06:08 PM   #2 (permalink)
View 05DCLB's Photo Gallery
Way way out of line, most 1M and 3M V-6s dont need anything more than a new T-belt and outer belts. Water pumps,idlers,even crank and cam seals rarely need to be replaced. I'm thinking $300.00 should do it.
05DCLB is offline   Reply With Quote
Old 08-06-2009, 08:09 PM   #3 (permalink)
View kahrta's Photo Gallery
Was it suggested that you replace the pump? I have an 03 with 155k and I haven't needed to replace anything. As a college student myself, I do most of the work myself after extensive research. 1100 is WAY overpriced, take it somewhere else maybe? I'd say just the tbelt needs replaced.
kahrta is offline   Reply With Quote
Old 08-06-2009, 08:18 PM   #4 (permalink)
View edbro's Photo Gallery
I would replace the pump. The pump itself is relatively inexpensive but if it goes out you have to do all the same disassembly as changing the timing belt. So, the conventional wisdom is that while you have it all apart anyways, change the pump.
Having said that, $1100 is way out of line. You could get it done for between $400 t0 $600 at an independent garage.
edbro is offline   Reply With Quote
Old 08-16-2009, 08:58 PM   #5 (permalink)
View ChiTDI's Photo Gallery
+1 on what he said.
You've gone a long way on that pump. 6-8 hundred seems more accurate. But spend it once, not twice.
ChiTDI is offline   Reply With Quote
Old 08-29-2009, 02:15 PM   #6 (permalink)
View CraZySteve's Photo Gallery
I just got a quote from my local Stealership for my 03 Av w/97K
$399 For Timing belt / Drive belt Replaced
$249 additional to get Waterpump Replaced stating cost of Water pump is $180! WTF! I can buy a Full blown Hi-po Waterpump for my SB Chevy for $50!
So all in all $650 all said and done -- I feel that is reasonable and will most likely get it done..
But $1100 you are getting Smoked!
CraZySteve
2003 Avalon XLS
CraZySteve is offline   Reply With Quote
Old 08-29-2009, 05:04 PM   #7 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3636250
Agreed. $600 would have been my estimate for timing belt and water pump replacement costs. Unfortunately, this specific repair, IMO, is one of the most abused among auto repair businesses, especially dealerships.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is offline   Reply With Quote
Old 08-29-2009, 05:18 PM   #8 (permalink)
Another Stealership in the area wanted $1000 if they did the plugs too... talk him down to $900, but still not getting it done there.. there is a reason I call them "Stealer"ships
CraZySteve
2003 Avalon XLS
Old 08-29-2009, 05:24 PM   #9 (permalink)
Do you feel lucky?
TrailDust's Avatar
Stealerships...right on! Once upon a time I had an Acura Legend that (long story short) I was forced by circumstances to take to a dealership. A simple timing belt removal came out as a $1,400 bill! I blew a gasket, but they would not release my car till I paid. I paid, took my car home, then immediately contacted the state attorney general's office and filed a complaint. The AG office's follow-up, plus my threat of a lawsuit which they would assist, caused the dealership to crumble and refund $800 to me. That was the last time I ever took my car to a stealership for major servicing under ANY circumstances. Lesson learned.
2002 Avalon XL
Old 09-05-2009, 10:38 AM   #10 (permalink)
tundra/tacoma's Avatar
View tundra/tacoma's Photo Gallery
Hi, i checked my local dealer and this is what i came up with
t-belt
drive belts
w/pump
t-stat
gskt
coolant
total parts $256.00
labor ??? depends on where you go, my local dealer is $89.00 hour.
so im thinking it should not be more than another $500 in labor.
Toyota 4ever!!!
tundra/tacoma is offline   Reply With Quote
Old 10-07-2009, 12:42 PM   #11 (permalink)
View supercoupe91's Photo Gallery
To the original poster, if you can find the cash it is recommended to replace the timing belt at some point before/if it gives out...it only makes sense to change the water pump also. Like someone above said, pay the labor once not twice.
Having been through a timing belt replacement with an Audi A4, the Toyota timing belt to me is like a walk in the park.
supercoupe91 is offline   Reply With Quote
Old 10-12-2009, 07:09 PM   #12 (permalink)
View Budhah's Photo Gallery
Paid $635 IN Marion Illinois... did not replace pump, said it looked good. $1100 way too high. Saying that, I would not let them touch my car any more, as they are trying to get extra money and not above making things go bad.
By the way,, You Sig Pic looks ike the video of my Colonscopy taken last year in Bangkok. LOL
Budhah is offline   Reply With Quote
Old 10-14-2009, 12:14 PM   #13 (permalink)
Gameroom cash: $818201
View zythr's Photo Gallery
That is expensive. Did they give you a break down on all the costs. For you other posters, remember whether the "stealer" or independents in some states they can charge a "shop" charge ( materials, maintain builiding, utilities, etc) on top of the cost of the parts, labor and taxes.
zythr is offline   Reply With Quote
Old 08-09-2010, 07:31 PM   #14 (permalink)
View maestro123's Photo Gallery
LOL reading this thread pretty much reminded me why I would *never* take my car to the dealership for repairs. $1100?! for a timing belt/water pump change? I paid less than half of that.
96 Camry LE (245,XXX mi)
maestro123 is offline   Reply With Quote
