is this the battery - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 08-08-2009, 11:54 AM   #1 (permalink)
View stonzee's Photo Gallery
is this the battery
The other day I noticed that my Avalon didn't start as smoothly as it normally does. The radio was also turned off. I never turn it off so this was strange.
Also all of the settings on the radio had been wiped out.
The clock, however, was fine and had the correct time.
The next day the car wouldn't start at all. It just made a clicking sound.
The lights came on however.
Today, it started but still not smoothly.
If it is the battery wouldn't the clock have been affected as well as the radio.
I've had no problems with the car until this.
Any ideas?
stonzee is offline   Reply With Quote
Old 08-09-2009, 12:41 PM   #2 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $281592
View csaxon's Photo Gallery
How old is the battery? It sounds like its starting to go.
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 08-09-2009, 01:51 PM   #3 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3636250
I'd bet the farm it's the battery. Buy a new one and install it, and your Avalon should fire right up.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is offline   Reply With Quote
Old 08-10-2009, 02:05 PM   #4 (permalink)
Thanks. I replaced the battery and everything is fine now.
Old 08-10-2009, 02:22 PM   #5 (permalink)
Do you feel lucky?
TrailDust's Avatar
Kewl! By the way, to Toyota Nation!
2002 Avalon XL
Old 01-26-2010, 10:12 AM   #6 (permalink)
View SullenScreamer's Photo Gallery
Just wondering what kind of battery did you get? I am looking at the batteries and i am confused between getting a battery that has 650 CCA(cold crank amps) or 560 CCA. Also what is the difference between 650 CCA 560 CCA.
SullenScreamer is offline   Reply With Quote
Old 01-26-2010, 10:41 AM   #7 (permalink)
View ehoff's Photo Gallery
I personally would go with the 650, more cranking power at startup, especially good in cold weather situations.
ehoff is offline   Reply With Quote
Old 01-26-2010, 11:41 AM   #8 (permalink)
^^What he said, but first check your owners manual for the minimum battery CCA that Toyota recommends for your car. Buy that or higher CCA.
