Originally Posted by Hajoca
The adjustment bolt has a 'locking' bolt to keep it snug. that is bolt that you see underneath.
Turn the adjustment bolt some more.
If you were able to turn that, then make sure the adjusting rod is not adding tension to the belt.
I'll look at that tonight a bit closer.
I've loosened the locking bolt which is below the adjustment bolt. Maybe I need to completely remove it.
Directly above that locking bolt, and connected to the adjustment bolt assembly is another small bolt. I assume that's part of the adjustment bold and shouldn't be moved. Maybe THAT's the locking bolt.
I'll tool around in there tonight.
