EVAP error codes - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 09-13-2009, 09:09 PM   #1 (permalink)
Davidkot
View Davidkot's Photo Gallery
Unhappy EVAP error codes
Hi all, sorry for my poor english...
I have avalon 2000, xls, with 117.000 mil. about a 1000 miles ago i got it for the first time, 3 lights, chk eng, vsc, and vsc off. Took my car to the mech. i don't recall the exact numbers of the error, but all of them were pointing on EVAP issues. The first thing i did, i replaced a gas cap with the original one from the dealership, it didn't help, after that replaced the solinoid which located under the car near the gaz tank, didn't help either, there is 5 solinoids more in this car under the hood, checked them all, and they working fine. this 3 lights at first were coming after approximately 400-500 miles, now after reseting them (unplagged the battery) it goes on after 20-30 miles, i am driving in the city, putting 93 fuel, and turning the engine off when i pumping fuel. This lights are not reflected in any way on the car nor the driving. I am desperate, don't know what else to do and what can be the problem or how to fix it. All kind of suggestion will be very welcome.
Thanks in advance!
Davidkot is offline   Reply With Quote
Old 09-18-2009, 05:03 PM   #2 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $281592
View csaxon's Photo Gallery
Get the code number and post back. Don't waste money before getting the diagnosis. You could buy a basic OBD-II code reader for what you wasted on guessing the problem. Get the codes.
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 09-19-2009, 01:07 PM   #3 (permalink)
Davidkot
Thanks for the reply, the codes are: P-0440, 0441, 0446....
Old 09-21-2009, 02:51 PM   #4 (permalink)
View BDS_237's Photo Gallery
0446 should be the evap canister under the car, above the rear axle, in front of the gas tank. I replaced mine, but there are plenty of resources to clean it out and repair the valves.
here is an article that I came across for the Sienna, but should be applicable for the Avalon, too. Very good pictures, and same general location.
BDS_237 is offline   Reply With Quote
Old 09-21-2009, 10:15 PM   #5 (permalink)
Davidkot
Yes, thanks, i know, i wrote about it, i've already replaced that one.....and it didn't help
Old 10-01-2009, 11:01 PM   #6 (permalink)
Davidkot
Found the problem...
Hi, i found eventually that on of the solinoids under the hood is not working, appears to be dead. i've replaced it almost 170$ . almost 300 miles after and evrything seems to be ok, so far so good, no lights came out, thank God. uuuffff.....piece of shit and so expensive.... thanks to all!!!
Old 10-02-2009, 02:47 PM   #7 (permalink)
tr7driver's Avatar
View tr7driver's Photo Gallery
Where is it located and how can you test it? I'm fighting the same battle on my 00 avy. --- Thanks
2000 Avalon XLS
2001 Highlander V6 Limited 4wd
2005 Mustang GT Convertible
1998 Avalon XLS 'RIP' (gave its life for us!)
1994 Honda Accord Wagon, 1979 Triumph TR7
tr7driver is offline   Reply With Quote
Old 10-02-2009, 06:18 PM   #8 (permalink)
Davidkot
There is 6 of them all together. One is under the car, next to the fuel tank, another 5 is under the hood, one of them is bellow little left near the radiator, another 4 are located under the plastic cover of the engine.
I tested them with my friend in a garagge with a simple device wich manually gives power to the solinoid instead of the main car copmputer, u can hear the solinoid "clicking", this is a good sign, but if it doesn't do anything it propbably dead, that's exactly what i did and that's the way i located the problem in my car....good luck, let me know if it helped
