01 avalon xls problem after possible faulty timing belt change - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 12-04-2009, 08:17 AM   #1 (permalink)
View stacks's Photo Gallery
I went to the toyota dealership to get my timing bel, water pump, and some other belts changed and a week later I started noticing problems. When I step on the gas it will make nosise like it's going but stall for a couple seconds, then the car will jump in motion. This is really irritating. Is this something that could have been caused by the place that did my timing belt job?
stacks is offline   Reply With Quote
Old 12-04-2009, 09:14 AM   #2 (permalink)
Offical TN Vendor
View toyotagregg's Photo Gallery
Possible issue
A known issue for this car is it's Idle Speed Control valve. Does your car ever have any trouble starting? If the timing belt was put on wrong your car wouldn't run right period. Maybe it is a transmission slip? Does this problem always happen now or just sometimes?
~ToyotaGregg of magauto
toyotagregg is offline   Reply With Quote
Old 12-04-2009, 09:48 AM   #3 (permalink)
It is happening now and pretty frequently when i press the gas. now that u mention it I did just get a transmission service done by my regular mechanic (not the dealership)..i think there was a leak or something but i'm pretty sure he replace the pan..do u think he might have messed up with something?
Old 12-08-2009, 11:11 PM   #4 (permalink)
View aznstylez's Photo Gallery
Go check your transmission fluid. Did Toyota do the timing after replacing the timing belt?
aznstylez is offline   Reply With Quote
Old 12-27-2009, 10:25 PM   #5 (permalink)
Resident Wiseguy
Riick's Avatar
View Riick's Photo Gallery
Doubtful that it's timing belt, though It has happened that that they install it one-notch off.
Sounds like what used to be called "hesitation".
I'd clean up the MAF & see what happens; that usually helps.
Also, try several cans of fuel injector cleaner in a row.
No funky lites on dashboard ???
One Tequila, Two Tequila,Three Tequila...Floor
.Gen 3 - 2005 Touring Black on Black
.2nd Toy: BMW 328ic Convertible
Riick is offline   Reply With Quote
Old 01-01-2010, 12:21 PM   #6 (permalink)
Toyota owner since 1985
View FlaAv01's Photo Gallery
Really appreciated this thread. My 01 xls is due for timing belt, water pump, valve cover reseal, etc.
Will have it done at dealership. They have done good so far.
Have noticed slight "hesitation" on accelerating and will keep eye on it.
Thanks again
FlaAv01 is offline   Reply With Quote
Old 01-02-2010, 10:11 PM   #7 (permalink)
Resident Wiseguy
Riick's Avatar
Get whole 9-yards.
Don't forget air filter, pvc valve, fresh antifreeze, NEW belts and new hoses.
Somewher on here are instructions on pulling & cleaning the MAF (( mass airflow sensor )) which died on my car early -talk about hesitation!!
