Auto-off headlights misbehaving & draining battery - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 12-11-2009, 09:19 PM   #1 (permalink)
View preacherzson's Photo Gallery
2nd Generation Auto-off headlights misbehaving & draining battery
The auto-off function on the headlights of my 01 Avy XLS has left me stranded a couple of times this month.
What controls the auto-off function?
  • the headlamp switch?
  • or a relay?
Thanks in advance.
preacherzson is offline   Reply With Quote
Old 12-24-2009, 03:23 PM   #2 (permalink)
View toyomoho's Photo Gallery
The headlight switch grounds a wire coming from an electric control unit.
The light sensor is wired into this control unit.
A relay control power the lights.
Can you manual turn off the headlights? The drivers door switch is wired into the circuit, make sure this switch works.
Old 12-25-2009, 10:47 AM   #3 (permalink)
I can still turn off the lights manually. I'll check the door switch. Thx.
Old 09-22-2010, 12:16 PM   #4 (permalink)
View Dobrydad's Photo Gallery
My wife's '00 Avalon has developed the same problem a couple of weeks ago. She always leaves the light switch in the Auto mode, so she doesn't have to remember to turn them off. It is now draining the battery. I tried troubleshooting by covering the dashboard sensor with my hand & the lights turned on, then turned off a few minutes after I removed my hand. I thought I had it solved, but now it's back. Is this a fix-at-home deal?
Dobrydad is offline   Reply With Quote
Old 09-22-2010, 02:03 PM   #5 (permalink)
It was a diy home fix for me.
It turned out that my trunk light wasn't turning off consistently because the tab that has the button controlling the light was bent. I took out the latch, straightened the tab and voila, problem solved.
Don't know if that will be your issue, but I hope it helps. It took me a while to find it because it was intermittent and hidden.
Old 09-22-2010, 03:39 PM   #6 (permalink)
I wrench, therefore I am!
Gameroom cash: $214400
View TedL's Photo Gallery
On my '03, when I leave the HL in Auto, they turn off after about 2 minutes if I take no action other than getting out and closing the door. If I lock it with the fob, the HL go off immediately.
I can also kill the HL immediately by rotating the switch one position and returning it to auto. Like when I park in home garage and don't lock.
It seems like your timer function is not working properly. The "countdown" may be triggered by a door opening as detected by door switch (mentioned above). Do your dome lights come on?
(Oh, I'll wager the control answer is "Neither. The BCM." But that's a SWAG.)
TedL is offline   Reply With Quote
