2003 steering wheel shakes - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 12-19-2009, 09:48 PM   #1 (permalink)
View richardsonfh's Photo Gallery
Whenever I am driving slow (10-35mph), the steering wheel shakes. When I have the wheel balanced, it seems to stop for a few days. I have had the front end aligned, but no help with problem. I took it to a dealership when under warranty, but they wanted to charge me for deciding what was wrong. I just keep getting the tires balanced about every 2 months. Has anyone had this problem? Can someone please help me? I am certainly no mechanic.
richardsonfh is offline   Reply With Quote
Old 12-19-2009, 09:55 PM   #2 (permalink)
View CJCride's Photo Gallery
Are they Genuine Toyota rims? Sometimes aftermarket rims can shift slightly after hitting bumps & you get steering vibration.
Welcome Aboard.
CJCride is offline   Reply With Quote
Old 12-20-2009, 08:50 AM   #3 (permalink)
Yes, everything on the car is Toyota. I have wondered about the rim being warped, but the place where I get the tires say the wheels are fine and the tires are fine. Thx for the fast reply.
Old 12-21-2009, 05:57 PM   #4 (permalink)
any other suggestions from someone? Getting tired of balancing tires! thanks in advance..
Old 12-24-2009, 03:30 PM   #5 (permalink)
View toyomoho's Photo Gallery
Try swapping the front and rear wheels/tires to determine if this makes a difference.
Sometimes a tire can be out of round or have other problems.
Check the front brake rotors for warpage and axles for run out.
Old 12-28-2009, 10:06 PM   #6 (permalink)
View poolvibe's Photo Gallery
Find a shop that can do a road force balance and check the run out on the rims as well. You have a bad tire or a bad rim. Explain to the tech that you want the truth! I use the local Americas Tire because they are great at balancing and have sent tires back in the past if problems developed.
poolvibe is offline   Reply With Quote
Old 12-28-2009, 10:49 PM   #7 (permalink)
Resident Wiseguy
Riick's Avatar
View Riick's Photo Gallery
Sounds to me like a tire (or two?) is "out of round", or has a broken belt. However, I had same sort
of thing happening intermittently on a BMW; the problem turned out to be a worn suspension part.
One Tequila, Two Tequila,Three Tequila...Floor
.Gen 3 - 2005 Touring Black on Black
.2nd Toy: BMW 328ic Convertible
Riick is offline   Reply With Quote
Old 01-03-2010, 07:14 PM   #8 (permalink)
View jaeb0922's Photo Gallery
out of round all day. i have the same issue. i know if u got some mud/snow build up under the front tires this also will do the shake
jaeb0922 is offline   Reply With Quote
