How long between timing belt changes? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 01-08-2010, 09:07 AM   #1 (permalink)
View tcozza's Photo Gallery
2nd Generation How long between timing belt changes?
I just bought a 2001 xl with 335.000 miles on it and looking through its records I see the last time the timming belt was replaced was at 265,000. Am I right that it would need changed at 355,000. Also none of the lights other than the LCD display work on my radio. Is there a bulb or a few that can be changed to get the radio to light? The light for the D in the gear selection display on the dash isn't working. Bulb? Thank You
tcozza is offline   Reply With Quote
Old 01-08-2010, 09:18 AM   #2 (permalink)
Gameroom cash: $817701
View zythr's Photo Gallery
Timing belt. Yes you should change it or at the very least check to see the condition of it, also, check/replace the oil seals (crankshaft, camshaft) Radio lights, could be a bulb. The D selector in the dash does use a bulb, to change it, though, you would have to remove the instrument cluster. If you can live without it, then I would not worry about it.
zythr is offline   Reply With Quote
Old 01-11-2010, 09:28 AM   #3 (permalink)
View ChiTDI's Photo Gallery
Before popping for a TB job, though, check the engine carefully for any sludge issues. 335k is a lot of mileage, and if no symptoms appear, perhaps get the oil service info and keep using that.
ChiTDI is offline   Reply With Quote
