Shaking/Shimmy w/Highway Driving - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 02-27-2010, 10:04 AM   #1 (permalink)
2000 Avalon XLS Owner
Easywin's Avatar
View Easywin's Photo Gallery
2nd Generation Shaking/Shimmy w/Highway Driving
While driving on the highway (and at slow speed to a lesser extent), the steering wheel shakes left to right. I have had the tires balanced twice since I got new tires. While changing the oil I decided to check the tie-rod ends and swaybar linkage. All of them are loose on all four corners. Is this normal?
I don't think the problem is in the struts, because I don't notice an excess of bouncing while going over bumps. I did check the boots for the CV joints and all is well there. The car does have 140K miles so anything is possible.
I have found a shop, that supposedly will tell me what is "wrong" and let me try and fix it myself, should I take it there and see if they can diagnose it for me?
On a semi-unreladed note: Are there warning signs before the CV joints start clunking? While checking the tie-rods and swaybar ends, I tried turning one side of the CV, similar to checking the wear on a U-joint, and everything was tight.
Stock 2000 Avalon XLS
Easywin is offline   Reply With Quote
