Replace 2001 avalon xls v6 radiator - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 03-01-2010, 05:02 PM   #1 (permalink)
View go2rjm's Photo Gallery
2nd Generation Replace 2001 avalon xls v6 radiator
The top plastic connection of the radiator of a 2001 Avalon cracked and broke off under the hose clamp. I plan to replace radiator, it appears from my reading there may be transmission and engine coolant lines to radiator. Is there any advice on radiator replacement or is it straight forward? I have replaced Toyota Corolla radiator in past very basic all metal construction.
Thanks
go2rjm is offline   Reply With Quote
Old 03-03-2010, 09:01 AM   #2 (permalink)
Thanks
Pretty straight forward for anyone replacing. Disconnect A/T lines and upper/lower hoses as well as some electrical connections and pull straight up. Take off 2 fans, reinstall on new radiator and reverse process.
Old 03-03-2010, 01:34 PM   #3 (permalink)
View kegunder's Photo Gallery
I'd suggest that you closely check the threads on the radiator where the pipes connect to the transmission cooler. I had a replacement radiator that had an extra bit of thread material which prevented a solid connection. A read PITA.
kegunder is offline   Reply With Quote
