http://i963.photobucket.com/albums/a...8/IMG_8553.jpg
"My question, since this is very close to the water pump, is this my problem? I have heard that a bad pump will loose water out the weaping hole, I just assumed it would be small droplets or a very small quantity. My guess is that I lost 2 gallons in about 15 minutes. Would this be normal for a bad water pump? 2000 Toyota Avalon XLS, 240,000K miles. Maintained very well."[/quote]
"The timing belt was soaked and I am highly confident the timing belt has never been changed before, there were no witness marks on any of the bolts, nuts, etc. The belt does have some minor fraying and inside the cover there is a large buildup of timing belt material including some fray, looks like a small rat nest. I am now 100% convinced its my water pump that was the problem."[/I]
I often wondered just how far one could go on the original timing belt etc. I have heard that a water pump can go twice the miles of the timing belt. Sounds like you got 240,000 miles on the original belt, pump and everything else. That's really interesting, and I wonder if the parts in the newer Avalons are as well made.
