What is this part???? (2000 Toyota Avalon) - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 03-17-2010, 07:45 PM   #1 (permalink)
View jsm3's Photo Gallery
What is this part?
The little plastic nipple broke off (as indicated with arrow)
jsm3 is offline   Reply With Quote
Old 03-18-2010, 03:53 PM   #2 (permalink)
View brinkley's Photo Gallery
Yep. I did the same thing, it's a solenoid of some type, I just went to advance got a little vacuum "tee" or connector thingy and used plastic weld to put it in a voila g2g
brinkley is offline   Reply With Quote
Old 03-18-2010, 08:04 PM   #3 (permalink)
Gameroom cash: $203600
View Donald E. George's Photo Gallery
I believe that is part of the emission control valve set. These solenoids cantrol the air intake valves and I believe the evap canister.
Donald E. George is offline   Reply With Quote
Old 03-28-2010, 08:25 AM   #4 (permalink)
View camry6's Photo Gallery
This is a vacuum switching valve (VSV). This one controls the ACIS (Acoustic Control Induction System). This valve diverts vacuum to the actuator on the left side of the intake (follow the rubber hose). This happens at approximately 3800~4000 RPM. This changes the length of the intake runners and uses sound waves (that's the acoustic part) that are generated in the intake and bounces them off the rear chamber wall. The resulting reverberation of sound waves forces air into the engine. This increases power at higher RPM's. This system was developed by Toyota engineers in 1991 for the 1992 Camry 3VZ-FE V-6 engine. The system was so successful that it was then used on many Toyota engines since then and is still used today. This VSV can be found at many scrap yards from any Toyota engine that has an ACIS system.
camry6 is offline   Reply With Quote
