transmission fluid ? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 04-25-2010, 10:36 AM   #1 (permalink)
View freddy123's Photo Gallery
hi everybody! My 2003 avalon calls for dexron 3 trans fluid.I do alot of my own general services and when i went to the local parts store was told castrol multi import was correct type fluid. The label states particularly for toyota typt T-4 BUT MET REQUIREMENTS Of dexron 3 also.Maybe its my own imagination but it seems there is a very slight whine between gear changes.everything else seems smooth and ok.Anybody else tried this fluid? Please tell me this is the right fluid for my car1. Why do the oil companies make everything so complicated?Are all trans fluids going universal now?
freddy123 is offline   Reply With Quote
Old 04-26-2010, 06:56 PM   #2 (permalink)
View 05DCLB's Photo Gallery
I've been told you can put T-4 in a DexIII car but not the other way around, DO NOT mix the new WS fluid with anything else. I always use what is stamped on dipstick.
05DCLB is offline   Reply With Quote
Old 04-30-2010, 06:10 AM   #3 (permalink)
View ChiTDI's Photo Gallery
freddy - I think you are good with that fluid. How many quarts drained and did you have two drain plugs?
My '02 has a separate drain plug for the differential but fills from the dipstck. I was curious as to your '03s configuration.
ChiTDI is offline   Reply With Quote
Old 04-30-2010, 07:08 AM   #4 (permalink)
View hughesar's Photo Gallery
On my 03' with a drain from the main transmission case plug I will get 3.5 qts out (measured). I have heard there is an additional plug for the differential, but have never been able to locate it. Anyopne else find this second drain plug on an 03?
hughesar is offline   Reply With Quote
