2000 Avalon Fuel Filter Change Procedure - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 05-21-2010, 09:16 PM   #1 (permalink)
View clark_bailey's Photo Gallery
When I wanted to change the fuel filter on my Avalon there was little instruction that I could find. So for the next guy here it is. Yup, I skipped the fuel line de-prime procedure, not enough gas spills to need to waste time with pulling fuses and running car till it quits.
1. Turn the car engine off!
2. Fuel filter is located under the intake tube between air filter housing and the intake housing. You can remove the stuff above the filter if you want or work around it. I removed the air filter housing top and the plastic thing between the air filter and the metal intake housing for easier access.
3. Remove the top gas line shield by pressing on both sides and pulling straight up.
4. Press the gray tabs (2) on the end of the gas line with your finger nail or a small flat head screwdriver one at a time. You will hear a click when the clip disengages.
5. Pull upper gas line off (have a small rag under since some gas will spill).
6. Bottom line required tubing wrenches (12mm and 17?or 18mm to break loose and about 30 minute soak with pb blaster oil.
7. Remove the filter from the bracket (8mm bolt).
8. Replace filter in reverse order.
9. Turn key on and off a couple of times to run the fuel pump.
10. Crank it up and go.
clark_bailey is offline   Reply With Quote
The Following 2 Users Say Thank You to clark_bailey For This Useful Post:
azsimonsez (05-30-2010), Sammydog (05-24-2010)
Old 08-18-2010, 01:19 AM   #2 (permalink)
View 89corolla4wd's Photo Gallery
does all the 2nd gen avalons have an external fuel filter? If not when did they get rid of it ?
89corolla4wd is offline   Reply With Quote
Old 09-11-2010, 09:11 AM   #3 (permalink)
View ChiTDI's Photo Gallery
The '02s have it, I know that.
ChiTDI is offline   Reply With Quote
Old 09-12-2010, 07:47 PM   #4 (permalink)
I wrench, therefore I am!
Gameroom cash: $214400
View TedL's Photo Gallery
Ditto '03.
TedL is offline   Reply With Quote
Old 11-20-2010, 12:43 AM   #5 (permalink)
View lancho's Photo Gallery
Thumbs up Avalon fuel filter........
Great notes on the change out - used these and worked great.... I did however encounter a problem... the after market ones do not work here... the threading does not go deep enough to complete a connection on the bottom..... I tried Napa's and Autozone's - so even if you are in a pinch (weekend - like me) best to wait until the dealership opens and get it from toyota........
2000 Avalon..... great cars.....
lancho is offline   Reply With Quote
