Power Window Question - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 06-01-2010, 08:09 AM   #1 (permalink)
tr7driver's Avatar
View tr7driver's Photo Gallery
The power window in my rear door (driver's side) quit working. (Fortunately in the up position). When I push the switch I hear a click and the interior light dims for a second, so I'm thinking the switches work and the problem is with the motor or something mechanical is binding. Any advice on how to troubleshoot this? How difficult is it to remove the interior trim to check out the window? This is a 2000 xls. Thanks!
2000 Avalon XLS
2001 Highlander V6 Limited 4wd
2005 Mustang GT Convertible
1998 Avalon XLS 'RIP' (gave its life for us!)
1994 Honda Accord Wagon, 1979 Triumph TR7
tr7driver is offline   Reply With Quote
Old 06-10-2010, 08:55 AM   #2 (permalink)
tr7driver's Avatar
anyone?
OK, what is the best way to remove the door pannel without breaking anything so I can have a look inside?
Are the window motors interchangable? Can I try one from another door and see if it works as a test?
Thanks
2000 Avalon XLS
Old 06-10-2010, 10:58 AM   #3 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3635750
I have the same problem with my driver's window. It's been diagnosed as a bad motor and also dirty guide tracks, but since I rarely roll my windows down anyway I haven't bothered to get it fixed. This seems to be a very common issue with the Avalon regardless of year of manufacture. If anyone chimes in with info about how to tackle the repair I will probably do it myself as well.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is online now   Reply With Quote
Old 06-20-2010, 11:17 AM   #4 (permalink)
View JurassicJet's Photo Gallery
If you PM me and give me your email I can send you the shop manual PDF for doing body work, which the door is included in that. It is not very hard to get the door panel off, but if you don't know what you are doing you will break stuff.
JurassicJet is offline   Reply With Quote
Old 06-24-2010, 01:21 PM   #5 (permalink)
Gameroom cash: $236150
View grandpapa's Photo Gallery
so anyone has idea about how much it will cost for part and labor to fix the window problem?
grandpapa is offline   Reply With Quote
Old 06-25-2010, 02:58 PM   #6 (permalink)
Just a quick search on the internet and I found the motors running from $96 to $122. Those are for remanufactured systems.
As a side note.... Not too long ago I had to replace the window motor (sometimes they are called "window regulators") on my 2000 Chrysler Town and Country. The dealer wanted almost $300 just for the window motor. I called a large salvage yard to see if I could get a used motor. They said "we will do you one better, you can get a NEW aftermarket part for $80 from us". The only difference between the Chrysler and the aftermarket was the aftermarket didn't say "Chrysler" on it.
It took me about 2 hours to change it out and I saved myself at least $300.
