Starting Problems intermittent - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 06-17-2010, 03:47 PM   #1 (permalink)
View frosty170's Photo Gallery
I have a 2000 Avalon,141k miles, sometimes I have a hard time starting it. I turn the key and it will just click, try again and it will start. I have a new battery, Voltage at idle is at 14. I turn the lights on with the air cond and it drops to 12.6, could this point to the Alt having problems under load ?
Thanks
frosty170 is offline   Reply With Quote
Old 06-17-2010, 09:43 PM   #2 (permalink)
BiXLL's Avatar
View BiXLL's Photo Gallery
sounds more like a starter/selenoid problem to me.
2002 Avalon XLS
2004 Nissan Titan SE
2011 Hyundai Sonata SE
BiXLL is offline   Reply With Quote
Old 07-12-2010, 09:55 PM   #3 (permalink)
I wrench, therefore I am!
Gameroom cash: $214400
View TedL's Photo Gallery
What he said^^^^^, if your connections including grounds are clean and tight.
TedL is offline   Reply With Quote
Old 07-13-2010, 11:50 AM   #4 (permalink)
View chuckoff's Photo Gallery
Contacts in starter solenoid are probably worn. Remove starter, remove solenoid cover plate and see if contacts and plunger are worn/pitted. All replaceable. Not necessary to replace entire starter like many shops do.
chuckoff is offline   Reply With Quote
Old 07-13-2010, 05:20 PM   #5 (permalink)
Thanks
Thanks for the feedback, I went ahead and bought a starter/solenoid, $68 bucks from a link I found here. Problem solved, but now it seems the starter stays engaged too long.
Old 07-16-2010, 03:57 PM   #6 (permalink)
Starter staying engaged could be the replacement solenoid sticking. Why did you replace the whole solenoid? Much easier to just replace fried contacts and plunger.
Old 07-19-2010, 09:47 AM   #7 (permalink)
when I called toyota the guy talked me out of buying the parts for the solenoid, he said it was hard to take a part. After getting the new Starter it didn't look so hard.
