Are they fog lights ? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 06-23-2010, 07:34 PM   #1 (permalink)
View rod jr's Photo Gallery
Have a 2000 Avalon XLS, noticed the lower front lights are not working, checked the fuses and are ok. I know there is a fog light switch on the auto light pod but it seems that when using the turn signal that these would illuminate the road at night when turning either direction, am I wrong about this? The manual say go to dealer when not working but how do I make them work? Looks like the only access is by removing the complete lower plastic cowl.
rod jr is offline   Reply With Quote
Old 06-24-2010, 08:43 AM   #2 (permalink)
View bobflood's Photo Gallery
fog lights
Those are definitely fog lights; they go on and off with the switch on the turn stalk in my '02. I believe headlights also have to be on for fog lights to come on. They do not come on with the turn signal to illuminate in corners.
bobflood is offline   Reply With Quote
Old 06-26-2010, 05:36 PM   #3 (permalink)
KoG506's Avatar
View KoG506's Photo Gallery
Have you checked the bulbs to see if the bulbs are still working? (if you have to change the bulbs, they are same as low beams 9006)
Check fuse boxes to see if blown fuse?
KoG506 is offline   Reply With Quote
Old 06-26-2010, 10:10 PM   #4 (permalink)
I have not checked the bulbs as there seems no easy access to them. The lower cowling looks like its all one piece including the wheel wells. Is there any easy way to access the bulbs ?
Old 06-27-2010, 12:32 PM   #5 (permalink)
KoG506's Avatar
If you have long and skinny arms you can unplug through the Passenger side of the engine. if you don't, do same thing as the driver side.
The driver side, you have to get under the car and unscrew the bolts (like 3 or 4) and pull down the plastic cover down and stick your hand up there and unplug.
Old 08-13-2010, 04:17 PM   #6 (permalink)
View dapetrick's Photo Gallery
Driving lights not fog lights
They're driving lights, not fog lights, as they make the fog much worse. They light up the road at the bottom more. There is a second control on the headlight stalk for them, that is just on/off. That's if you have the factory ones. It almost sounds like an after market mod.
dapetrick is offline   Reply With Quote
