ATF For 1998 Camry 4 cyl - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 07-02-2010, 08:22 PM   #1 (permalink)
View ed0628's Photo Gallery
I'm planning to do a drain and fill on my car's tranny. I understand it requires Dexron 3. Can I safely use Dexron 4.
I also have a 1999 Dodge Caravan which used Dexron 3. A Mopar TSB upgraded the 3 to a 4 and made it retro for Mopar cars and trucks. Apparently the 4 is superior to the 3 and has been installed in my van.
Are any of you aware of any upgrade for Toyota vehicles?
I would appreciate a discussion of this subject and thank you for your participation.
ed0628
ed0628 is offline   Reply With Quote
Old 07-02-2010, 08:52 PM   #2 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $281092
View csaxon's Photo Gallery
Dexron VI is the follow on to III. GM didn't spec a dexron IV. Your Dodge probably uses the ATF+3 Spec transmission fluid. That is not a Dexron spec fluid. Most newer Toyota's use the ATF-WS spec fluid.
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 07-02-2010, 09:43 PM   #3 (permalink)
Toyota does have an ATF fluid designated T-IV but it is not designated for any Toyota after 1990 that is using dex II or dex III.
The Following User Says Thank You to csaxon For This Useful Post:
ed0628 (07-04-2010)
Old 07-04-2010, 10:57 PM   #4 (permalink)
csaxon,
Thank you for responding to my query. You are correct, my 1999 Caravan takes ATF 4, not Dexron 4. Looks like I will be using Dexron 3 for D&F on my Camry.
Thanks again for your interest and clarification.
ed0628
Old 07-12-2010, 08:37 PM   #5 (permalink)
I wrench, therefore I am!
Gameroom cash: $214400
View TedL's Photo Gallery
I would suggest you do what I've done...switch over to Dexron VI (GM skipped from 3 to 6). It's synthetic, basically to meet the tough performance standards to qualify for the label, and replaces all previous versions of Dexron.
I get SuperTech Dexron VI at Walmart fro $3.77/qt. GM licenses the product, and everyone has to meet the same standards.
It's been in our 3 Toys ('97 Camry, '99 Avalon, '03 Avalon) for a combined 65k miles, and the shifting smoothness is excellent.
TedL is offline   Reply With Quote
The Following User Says Thank You to TedL For This Useful Post:
ed0628 (07-13-2010)
Old 07-13-2010, 12:26 PM   #6 (permalink)
TedL,
Thank you for your info. Can I do a drain and fill, or should I consider a flush first?
I appreciate your courtesies.
ed0628
Old 07-13-2010, 01:42 PM   #7 (permalink)
Well, to get the full benefits of the fluid upgrade, you want a full change.
I actually do the flush every 30k, disconnecting the return hose from the cooler in the rad. But I don't bother to drop the pan. As noted elsewhere, the "filter" is like a screen.
Figure on using 12 - 13 quarts for the flush. If you don't have a second car around, have 16 qts on hand when you start, because Mr. Murphy was a bloody optimist.
Use a clear tube (Lowes, HD) to make it easier to track the fluid color change to new looking.
Old 07-13-2010, 09:35 PM   #8 (permalink)
ATF for 1998 Camry 4cyl
TedL,
Thank you again for all of your info. It is very helpful and I plan on changing by flushing.
ed0628
