2000 Avalon - gas tank issue - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 07-15-2010, 02:06 PM   #1 (permalink)
View david_2000_avalon's Photo Gallery
We have a 2000 Toyota Avalon,
when we try to fill the gas tank up recently, the pump click off very soon.. No matter how we adjust the pump, the pump click in every few minutes...
any ideas? probably will need to take it to the shop..
david_2000_avalon is offline   Reply With Quote
Old 07-15-2010, 08:41 PM   #2 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $281092
View csaxon's Photo Gallery
Start here with the vent hose. The small hole is connected to the venting system which sometimes plugs up with dirt or spider webs etc..
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 07-15-2010, 08:42 PM   #3 (permalink)
The small hole is the top of this skinny vent tube.
Old 07-15-2010, 08:45 PM   #4 (permalink)
The skinny vent tube ends in a rubber fuel line to the charcoal canister.
Old 07-15-2010, 08:51 PM   #5 (permalink)
Disconnect the rubber hose and snake a wire through the metal pipe or try compressed air to blow it out. If that doesn't work then you may have a bad vent check valve on the charcoal canister.
Old 07-16-2010, 09:54 AM   #6 (permalink)
thanks, I will check this when I get back from a business trip next week.
Car will be setting at the office parking lot for a week..
Old 07-23-2010, 10:54 AM   #7 (permalink)
View hsdennis's Photo Gallery
For a couple of days now, I have noticed a gas smell whenever I would stop the car and first get out of it. Then just this morning it threw some check engine codes (p0440, p0441, and p0446). I'm guessing maybe this is related to the canister you mentioned?
hsdennis is offline   Reply With Quote
Old 07-27-2010, 10:49 AM   #8 (permalink)
Yes but start with the gas cap and make sure it seals. Also possible causes..Over fill check valve in fuel tank leaking, charcoal canister flooded with fuel, ccv-vsv stuck open
Old 07-27-2010, 10:50 AM   #9 (permalink)
