Overheating/Coolant mystery
This thread was previously titled "OBD II Codes....can they be obtained without a scanner?"
I just had an opportunity to dig into the car and see what's going on. Codes aren't an issue now as the system apparently reset itself and all engine lights are now off. I'll begin with what I wrote earlier and add the updated information.
Earlier I wrote...
It's a 2000 Toyota Avalon XLS V6 with just over 90k miles on it. Yesterday, after just 3-4 miles of driving on an already warm engine (driven earlier that afternoon), the engine light lit up. Shortly after that the VSC lights lit up. I've heard that the check engine can trigger the VSC lights so I thought nothing of it. A couple miles later the temp gauge pegged and I could both smell an odor and hear an unusual, barely audible "scratchy" sound. I assumed a problem with oil/coolant.
Initial visual inspection showed no fluid leaks...just condensation off the AC. I let the car sit and cool down and still no sign of leaks. Had it towed home and I plan to dig into it today to see what is going on.
Vehicle's owner who was in the car at the time says a mechanic told her, during her last vehicle repair, to keep an eye on her radiator as it "might be going". I saw no indication that there was a radiator issue. Thermostat malfunction perhaps?
As of a few minutes ago, here's what I discovered....
So, I began filling the radiator with straight H20 just to see how much it'd take. It took more than 1.5 gallons. Apparently, since yesterday quite a lot of coolant disappeared. Either that or the coolant level was already extremely low but I find it difficult to believe the owner could have driven 30+ miles earlier during the day yesterday on almost no coolant without overheating. Then again, maybe she did. She certainly didn't check the coolant level beforehand so I cannot say one way or another.
I started the vehicle and idled it while adding an additional 1/2 gallon or so to top it off. I continue to idle the vehicle until it came up to temp. Turned on the AC to stress the system and the fans turned on as expected. Ran it with AC for a few minutes which only moved the needle northward maybe 1/8" inch. Shut the AC off and the temp settled in about 1/4" south of the midpoint marker on the temp gauge. Looked beneath the vehicle, and still no visible leaks. Checked the dipstick and the oil seemed fine.
I then took it out for a spin for just a few miles. Temp didn't budge and everything seemed normal. Pulled into the driveway and checked again for leaks - nothing. Shut if off and let it sit, still nothing.
So it seems the overheating incident yesterday was due to the coolant system, but I'm baffled by what it could be. I expected to see at least some leaking or perhaps water in the oil, but I found nothing. While I haven't driven it hundreds of miles to stress test it, it's not currently running hot.
Any ideas? Could that much coolant have evaporated from the system yesterday afternoon and then through the evening as the engine cooled? If it didn't evaporate where could it have gone? I had not touched the radiator cap until today, but even assuming a bad cap I find it very difficult to believe a couple gallons would disappear. I'm stumped.
Reason: change in situation
