2001 Avalon P1155 code - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 07-22-2010, 08:54 AM   #1 (permalink)
led
View led's Photo Gallery
My car threw a check engine light and my scanner revealed a P1155. Which from research is an O2 sensor. What I don't understand is along with the check engine light it also lit the VSC and VSC off lights. Why did the car turn of the VSC system because of a bad O2 sensor??
Thanks,
Stephen
led is offline   Reply With Quote
Old 08-08-2010, 01:27 PM   #2 (permalink)
View maun's Photo Gallery
I have seen the VSC lights come on for the pollution codes. My guess is the VSC lights just come on when the MIL check engine light goes on.
Norman
2003 Avalon
maun is offline   Reply With Quote
Old 08-22-2010, 05:41 PM   #3 (permalink)
View jaybyrd's Photo Gallery
got the same code but got confliting postions of which o2 sensor it is did you find out which one it is
jaybyrd is offline   Reply With Quote
Old 08-22-2010, 06:36 PM   #4 (permalink)
jaybyrd,
My reply was only noticing that the VSC lights come on when the MIL lights. Someone also confirmed that VSC lights come on as part of the Avalon system. To check out the O2 sensor you need to get the data stream on the sensor whether the O2 sensor are operating correctly. I understand that there is a reader for about $150 that will give troubleshooting steps. If you are near the DC area, I can give you a read of whether the O2 sensor is operating correctly free.
Old 08-22-2010, 06:43 PM   #5 (permalink)
thanks ill have to get a better one the one i was using just gave me the number and had no live data thanks again i am a tech at a kenworth dealer but we use laptops thanks again
Old 08-22-2010, 06:48 PM   #6 (permalink)
jaybird,
I use a laptop from scantool software and it will give the trim details on the O2 sensor.
Old 10-09-2010, 10:10 AM   #7 (permalink)
thanks i was able to borrow the veryus from my snap on dealer and found that is bank 2 sensor 1 replaced and all back to normal it was the one closest to the raditor
