2003 XL Switch to Synthetic Oil? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 09-20-2010, 08:14 AM   #1 (permalink)
View kkovak's Photo Gallery
I have a 2003 XL with ~70K miles on the clock and was wondering about the benefits of switching to a synthetic oil at this point in the cars life. I have had the oil and filter changed every 3-4,000 miles since the beginning at the dealer.
Any thoughts or references will be much appreciated.
Thanks
Ken
Ken K.
Lehigh Valley, PA
2010 Highlander SE AWD in Magnetic Grey
2003 Avalon XL in Silver Spruce Metallic
kkovak is offline   Reply With Quote
Old 09-20-2010, 09:58 AM   #2 (permalink)
View ChiTDI's Photo Gallery
Sludge is the issue IMHO. I personally feel the synthetic cleans better and with a PCV system that is regularly maintained you should be able to log many more miles. However if there is some grunge in there, the syn will slowly clean it out, hence frequent oil changes and more $.
Tough call at this point. If there is a way to pull the valve covers and really see, that would be the determining procedure.
There are stories on this site about sludge with varied OCI and types of oil.
I find in my '02 that when I do drain the oil, I can let it drain for an hour after the first ten minutes, using a separate pan and get anywhere from 4 to 8 ounces.
Food for thought.
Good luck to you however you choose.
Personally I'd do the Pennz Platinum or Ultra for a while and see how much "dark" comes out.
ChiTDI is offline   Reply With Quote
Old 09-20-2010, 10:40 AM   #3 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $616031
View Zembonez's Photo Gallery
CLEAN oil is the one thing that will keep sludge at bay. Those who stretch the change intervals are more likely to have sludge buildup regardless of what oil they are using. Synthetics do allow for a bit longer between changes while offering superior protection to typical dyno oils. You can change between them at any time.
Zembonez is offline   Reply With Quote
