2002 Avalon XLS error codes 42 & 53 - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 09-27-2010, 02:19 PM   #1 (permalink)
View noela's Photo Gallery
What are the error codes 42 and 53 on the 2002 Avalon XLS?
Thank you.
noela is offline   Reply With Quote
Old 09-27-2010, 09:45 PM   #2 (permalink)
View OpticNerve's Photo Gallery
Dtc 42 & 53
From the link http://ww2.justanswer.com/uploads/sk...ncodechart.pdf, if you scroll down to the VSC codes you come up with for the DTC 42 "Malfunction in communication with the translate ECU' and for the 53 'Malfunction in master cylinder pressure sensor". To the right of each 'Detection item' will be the 'Trouble area'. I would start off with checking the brake fluid level. Keep us posted.
OpticNerve is offline   Reply With Quote
Old 09-28-2010, 04:49 AM   #3 (permalink)
Thank you, I will check this out and get back to you.
