2000 Avalon XL CEL Issue - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 10-28-2010, 01:45 PM   #1 (permalink)
View gsaddler123's Photo Gallery
Hi All! New Avalon owner and user here.
I purchased a 2000 Avalon XL with 156K miles a couple months ago. The CEL came on a few weeks ago and the code came up P0420. My mechanic reset the code. Since then, it has come on then turned itself off, then just today has come on again.
Each time it has come on, it has been within 30 miles of filling up the gas tank. I have turned the cap to one, two, three and no clicks thinking (hoping) it was as simple as that; doesn't seem to help, at least immediately.
Before I start swapping out sensors and cat. converters, any other cheaper ideas of what could be causing it? Thanks, G.
gsaddler123 is offline   Reply With Quote
Old 10-28-2010, 02:08 PM   #2 (permalink)
MagAuto.com Parts Master
View magautoparts's Photo Gallery
Sorry for the weird format but this is straight out of the manual. Let us know if you need a part.
Thanks
Gregg
A01674
Waveform of
A/F Sensor
Normal Catalyst
Waveform of Heated Oxygen
Sensor behind Catalyst
Abnormal Catalyst
DIAGNOSTICS
ENGINE
DI
71
Author: Date:
227
2000 AVALON (RM746U)
DTC P0420 Catalyst System Efficiency Below Threshold
(Bank 1)
CIRCUIT DESCRIPTION
The ECM observes the waveform of the heated oxygen sensor located behind the catalyst to determine
whether the catalyst performance has deteriorated.
If the catalyst is functioning normally, the waveform of the heated oxygen sensor located behind the catalyst
switches back and forth between rich and lean much more slowly.
When the waveform of the heated oxygen sensor located behind the catalyst alternates flutteringly between
rich and lean, it indicates that catalyst performance has deteriorated.
DTC No. DTC Detecting Condition Trouble Area
P0420
After engine and catalyst are warmed up, and while vehicle is
driven within set vehicle and engine speed range, waveform of
heated oxygen sensor alternates flutteringly between rich and
lean (2 trip detection logic).
Front exhauast pipe (front catalyst bank 1)
LH exhaust manifold (front catalyst bank 2)
Center exhaust pipe (rear catalyst)
Gas leakage on exhaust system
Heated oxygen sensor
A/F sensors
DI6T5
01
A18908
Idling
IG SW off
Warm up 4 min. 16 min.
(64 to 88 km/h)
40 to 55 mph
(56 to 72 km/h)
35 to 45 mph
DI
72
DIAGNOSTICS
ENGINE
Author: Date:
228
CONFIRMATION DRIVING PATTERN
(a) Connect the hand
held tester to the DLC3.
(b) Clear DTC.
(c) Warm
up the engine.
(d) Drive the vehicle at 40
55 mph (64 88 km/h) for 4 minutes.
(e) Drive the vehicle allowing speed to fluctuate between 35
45 mph (56 72 km/h) for 16 minutes.
(f) Check pending DTC.
NOTICE:
Drive with smooth throttle operation and avoid sudden acceleration.
DIAGNOSTICS
ENGINE
DI
73
Author: Date:
229
INSPECTION PROCEDURE
Read freeze frame data using the hand
held tester or OBD II scan tool. Because freeze frame records the
engine conditions when the malfunction is detected. When troubleshooting, it is useful for determining
whether the vehicle was running or stopped, the engine was warmed up or not, the air
fuel ratio was lean
or rich, etc. at the time of the malfunction.
1 Are there any other codes (besides DTC P0420) being output?
YES Go to relevant DTC chart (See page
DI14).
NO
2 Check gas leakage on exhaust system.
NG Repair or replace.
OK
3 Check A/F sensor (See page
SF79).
OK
4 Check heated oxygen sensor (See page
SF81).
OK
Replace front and rear catalysts (See page
EC
12 and EC15).
Replace all of the front exhaust pipe (front catalyst bank 1), LH exhaust manifold (front catalyst bank
2) and center exhaust pipe (rear catalyst).
magautoparts is offline   Reply With Quote
Old 10-28-2010, 02:09 PM   #3 (permalink)
Most likely bank one sensor one air fuel sensor.
Tags
cel, gas, p0420
