Very low gas mileage, help! - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 11-09-2010, 12:24 AM   #1 (permalink)
View jchfriends's Photo Gallery
Question Very low gas mileage, help!
Hi All:
I bought a used 2002 Avalon a month ago with 115K miles on it. I love everything about this car except for low mileage. I drive 95% city (frequent stop and go and mostly very short distance), and the mpg is only 14 with shell V-power premium gas. If I drive on highway, mpg could improve to around 20 for highway.
Other than this, I have not found anything unusual about this car.
Would a transmission or coolant flush help? I have to admit I do not know much about cars but I am trying to learn now.
I wonder if anyone has some suggestions, any information would be so appreciated.
Thank you.
jchfriends is offline   Reply With Quote
Old 11-09-2010, 12:15 PM   #2 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $281092
View csaxon's Photo Gallery
Do you know the cars maintenance history? You're in the tune-up mileage range (90-120k) when the spark plugs and timing belt need to be changed.
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 11-09-2010, 01:18 PM   #3 (permalink)
Thanks for your reply.
The problem is I do not have maintenance history of this car. The record of maintenance only shows one maintenance at 30K, nothing else. I doubt what the previous owner has done.
But I did a mechanical check when I bought it, I was told the dealer had just replaced the timing belt (with date on the belt). Hopefully I do not need to do it.
I am thinking to get the spark plug replaced, I heard it will improve MPG. But it also looks like a couple of hundred of bucks....
Old 11-09-2010, 07:11 PM   #4 (permalink)
If you can do it yourself the set of plugs is around $50. A lot of things influence gas mileage. Dirty air filter, fouled or weak spark plugs, tire pressure, dragging brakes, degraded 02 sensors (they start degrading around 90000 miles).
If the car was serviced by Toyota, they should be able to provide a computer printout. Good Luck.
Old 11-10-2010, 07:35 PM   #5 (permalink)
KoG506's Avatar
View KoG506's Photo Gallery
go to http://toyotaowners.com
sign up, its free, add your car vin # then go to service history
KoG506 is offline   Reply With Quote
Old 11-14-2010, 02:50 PM   #6 (permalink)
Thank you two.
I finally got a detailed report of my car. It is very helpful.
Old 11-14-2010, 03:10 PM   #7 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $996075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
An ignition system tune up will be a big help. Plugs, wires and if your car uses them-cap and rotor. I would also check ignition timing. Proper tire inflation affects mileage too.
The Jedi Speeder at CarDomain
Old 11-16-2010, 10:42 PM   #8 (permalink)
View maun's Photo Gallery
Your car maybe running lean hence the high gasoline consumption. The leaness maybe caused by an air leak on the air intake hoses so you may want to check for cracks/leaks in the air intake hoses or any parts contributing air to the engine. You could also put an OBD II reader/analyzer on your car to determine the efficiency of the engine operation and then look for the problem being coded, if any. An auto supply store like Advance Auto has obd II loaners.
hope this helps,
Norman
maun is offline   Reply With Quote
