Instrument panel brake warning light won't go away - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 11-24-2010, 12:59 PM   #1 (permalink)
View SpinningCone's Photo Gallery
last week the "break light" warning lit up on my instrument panel on my 2000 avalon xls. it stays lit all the time so i figured a light was out. i check the back lights and one of my taillights was out on the driver side (the little one in the bottom corner) got a replacement bulb and change it out. now everything looks good back there. but the warning light is still on. do i need to reset it somehow ?
SpinningCone is offline   Reply With Quote
Old 11-24-2010, 06:51 PM   #2 (permalink)
View Budabear's Photo Gallery
Disconnect the negative on the battery and it will most likely go away.
Budabear is offline   Reply With Quote
Old 11-29-2010, 08:59 AM   #3 (permalink)
View bobflood's Photo Gallery
If you are talking about the light that comes on when your emergency brake is set, that also warns when the brake fluid level is low. Check your brake fluid level.
bobflood is offline   Reply With Quote
Old 11-30-2010, 09:05 PM   #4 (permalink)
View jaybyrd's Photo Gallery
check the 3rd brake lite it has 2 bulbs
jaybyrd is offline   Reply With Quote
