Back to your original question, the VC gaskets and timing belt probably are not critical at this point. I assume that you can check the oil level yourself, and add oil if needed. (If not, forget everything I say, and get it all done now!) You can probably get by for months before getting it serviced.
I also think getting the water pump replaced at this point isn't necessary IF the coolant is changed regularly. Mines working fine at 170K, but I change the coolant myself. So, its a tradeoff. Some people can't or don't do anything themselves, and don't replace fluids at regular intervals. Those people should get new coolant and water pumps with each timing belt. But, if you have had good coolant in the car the whole time, you're buying extra life out of your cooling system, so don't waste the money replacing parts early.
(I will replace my my water pump at 180K when I replace the belt though. My bravery does have limits... and I like to be able to repair my car at the time of my choosing
