CEL code after engine replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 12-21-2010, 08:07 PM   #1 (permalink)
View CuttyVert's Photo Gallery
Question CEL code after engine replacement
The engine in my wife's 2001 Avalon blew over the summer. I managed to find one from a 2002 with 40K. The engine was installed and runs fine but now throws a code for the O2 sensor. The sensors are OK. If you clear the codes, the CEL will come on almost immediately when you start it back up. My mechanic is pretty good and it has him stumped. I've been looking around at ECU's and noticed that the 2002 has a different part number than the 2000-2001. Does anyone know if this could cause the problem?
CuttyVert is offline   Reply With Quote
Old 12-22-2010, 09:18 AM   #2 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $281092
View csaxon's Photo Gallery
What's the code?
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 12-24-2010, 12:28 PM   #3 (permalink)
Sorry for the delay. There are two codes showing up.
P1135
P1155
Like your freedom? Thank a veteran.
2001 Avalon XLS, 1995 Avalon XLS, 1995 Camry Coupe V-6
1994 Cutlass Convertible - the toy!
Old 12-24-2010, 08:19 PM   #4 (permalink)
Unusual for both to malfunction. Check the owners manual for the location of the A/F sensor heater relay. It's usually in the relay/fuse box next to the battery and air filter box. The relay is marked as A/F Heater or A/F HTR. Check for continuity between terminals 1 and 2 and NO continuity between terminals 3 and 5.
To check relay operation apply battery voltage across terminals 1 and 2 and check that there IS continuity between terminals 3 and 5.
Old 01-06-2011, 08:56 PM   #5 (permalink)
The relay checks out fine. The A/F sensors themselves check out and all the wiring passed continuity checks from the computer to the sensors. My mechanic thinks it must be the ECU and has one coming.
Back to my original post about the ECU: Since the Avalon has a smartkey (chip in it), if the computer is changed out will it need to be programed to be compatible with the key?
