EB1 Loction - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 12-30-2010, 09:07 AM   #1 (permalink)
View Shrek2's Photo Gallery
EB1 Loction
Hi all,
I have an Avalon 2000, and the CEL came on. Reading the code, it is P0330, which is the Knock sensor.
According to Toyota's maintenance manual, to diagnose the problem, you locate EB1 and swap Pin 1 and Pin 2 which are the connectors for the 2 sensors and see if the code will change to P0325 or not.
The problem is I cannot locate the EB1 connector and it is not mentioned in the manual! All other connectors are presented in a diagram but not this one.
Where can I find it this EB1 connector?
Here is a link of the fix procedure, but the EB1 connector here is a 3 wire, according to the Avalon manual, mine should be 4 wire.
http://www.************/fsm/1996/SIL...e/cip0325p.pdf
Thank you all in advance for the help.
Shrek2 is offline   Reply With Quote
Old 12-31-2010, 04:00 PM   #2 (permalink)
EB1 Location
Well,
After going through the manual again, I finally found it! Everything is OK now.
Old 01-01-2011, 09:06 AM   #3 (permalink)
View ChiTDI's Photo Gallery
Originally Posted by Shrek2 View Post
Well,
Shreker- glad it worked out for you.
Where did this EB1 location finally materialize? Perhaps the electronic connector at the knock sensor? The URL didn't give me anything so I'm running blind other than your description.
ChiTDI is offline   Reply With Quote
Tags
eb1, knock, p0325, p0330, sensor
