Originally Posted by timd02
Well, today I called 10 Toyota dealerships and asked their service departments about using the Toyota Type T-IV in my car. 7 of the 10 said to use what was listed on the dipstick which is Dexron II or III. I then went to Autozone and bought 10 qts. of Castrol Dexron VI which states that it is safe to use for Dexron III applications.
I then drained the fluid out of the transmission via the pan bolt and refilled with the Dextron VI. I then took the return line loose from the radiator and flushed it by pumping out 6 quarts and putting six new quarts in.
Hopefully I won't have any problems and 30% of the service departments telling me it was OK to use the Type T-IV wasn't a safe bet in my opinion. Just be sure and beware of what Haynes Service Manual tells you as it lists Toyota Type T-IV as the type of ATF to use.
Tim -I'm no fluid expert. My '02 calls for DexIII equivalents and that's what I've used w/30k intervals. Don't know about Dex VI. The T-IV I have used in '05 models that call for it. Nothing special.
When you drained, did you get 2 and 1/2 quarts or did you get closer to 3 and 3/4 quarts?
I ask because some models have two drain plugs to get the full amount drained. They fill from the dipstick tube but some have a separate plug for draining the differential (ATF). If you matched what you drained when filling and checked the level, there is no problem. I did that religiously for 90k until I found out mine has a second plug and I can get more fluid out each drain and fill. Helps if you want to flush out more of the old stuff and replace with fresher new fluid.
