Driver door won't open from inside. - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 01-09-2011, 10:55 AM   #1 (permalink)
View LuckY07's Photo Gallery
I have a 2000 Toyota Avalon and I can open the driver's side door from outside of the vehicle, however the door will not open from inside the vehicle. When you pull the handle nothing happens.
Is this a common problem? Any idea what I need to fix/replace?
Thanks.
LuckY07 is offline   Reply With Quote
Old 01-09-2011, 11:07 AM   #2 (permalink)
Tech1984's Avatar
Gameroom cash: $255850
View Tech1984's Photo Gallery
You say "drivers side door". The rear one has a child safety lock.
The front one will have a linkage rod or door handle problem which only can be diagnosed with the panel off.
Either isn't a big deal.
Bin wrenchin' on the Yota's since '84
2000 Tundra SR5 4.7 Ex Cab
2010 Camry LE 2.5
Cheers!
Tech1984 is offline   Reply With Quote
Old 01-09-2011, 11:24 AM   #3 (permalink)
how hard is the panel to remove? Any instructions for it?
* it's the driver's side front panel.
Old 01-09-2011, 11:35 AM   #4 (permalink)
Tech1984's Avatar
Do a search here will reveal instructions.
2010 Camry LE 2.5
Cheers!
Old 01-09-2011, 01:21 PM   #5 (permalink)
I got the door skin off and found the cable that connects the handle to the latch had snapped. I got the cable off on the handle side but I have no idea how to get it off on the latch side. I've removed quite a bit of pieces including that big plastic piece so I can look in where the latch is. Does anyone know how to replace the white cable on the latch side? Is this cable something I can buy from the dealer?
Thanks.
