White Smoke thru Exhaust at start-up - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 01-12-2011, 09:00 AM   #1 (permalink)
View tucker207's Photo Gallery
USA White Smoke thru Exhaust at start-up
I have 2000 Avalon XLS, mileage - 104K. Blows alot white smoke when I start after sitting for a period of time. Going thru a quart of oil every 300 miles. Some have suggested leaking head gasket, PCV value, etc. Stops after 60 seconds. I would assume that the head gasket would always leak if that was the issue.
tucker207 is offline   Reply With Quote
Old 01-12-2011, 04:34 PM   #2 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $281092
View csaxon's Photo Gallery
What color and type of coolant do you use? What does it look like? Is the oil on the dipstick milky? Is that 300 or 3000 miles? What's the service history are you original owner?
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 01-12-2011, 04:57 PM   #3 (permalink)
White smoke is usually condensation, burning trans fluid or coolant. If its only 60 seconds then it's probably condensation, since its been colder than usual in Florida. Does the engine overheat? Burning 1qt of oil in 3000 miles is possible. Leaking valve seals would usually smoke continuously. Cracked block or internal head gasket leak would also cause continuous smoke as coolant or oil burned.
Are there any signs of gaskets leaking on the engine or oil pan or drips on the ground?
Old 01-12-2011, 08:33 PM   #4 (permalink)
1 quart every 300 miles, Dip stick is not milky. No oil on the ground. Good service history. Looks like I am leaning towards a leaky/cracked head gasket. If the gasket was cracked, would it not smoke all the time?
Old 01-12-2011, 08:35 PM   #5 (permalink)
Gameroom cash: $106355
View Fortified Souls's Photo Gallery
you also need to look at your coolant for oily film they don't always mix together.
Fortified Souls is offline   Reply With Quote
Old 01-12-2011, 09:55 PM   #6 (permalink)
View poolvibe's Photo Gallery
Ring packs are stuck.... Run short OCI with MMO or rislone several timesm
poolvibe is offline   Reply With Quote
Old 01-13-2011, 01:56 PM   #7 (permalink)
Gameroom cash: $236150
View grandpapa's Photo Gallery
i read something about valve seal from Google. But that usually links to darker smoke, not white smoke.
If valve seal, someone mentioned it's kind of expensive to fix
grandpapa is offline   Reply With Quote
Old 01-13-2011, 02:17 PM   #8 (permalink)
I am going to try the rislone recommendation povided earlier. Potential for a quick remendy. I will advise as to the results.
