Originally Posted by BiXLL
Do you know what they did, or how they determined the struts were bad? Are you saying unless they are leaking, they are ok?
Sure. They simply ran it up on a lift and did a visual inspection.
The oem struts are oil filled, and if they're leaking they're bad. Or, perhaps just beginning to go bad.
Remember, I suspected mine were worn because of the ride. It was soft, wallowy, and a little bouncy over bumps - and more pronounced on one corner.
Various Internet commentators told me they couldn't possibly be bad at only ~30K mi., and that the "stealership" was lying. It was obvious when I pulled them and saw how much they were covered in oil that they had been leaking for some time and needed replacing. You can visually inspect them while they're on the car. Just turn the wheel all the way out and look at the struts.
I don't remember if it was all four, but I think both fronts were definitely gone. I made the right decision to do all four wheels however. I drove the car after replacing just the fronts, and it felt strange, kind of mismatched. Then I did the rears and it all came together.
How many miles on your car? You said you bought it used. Do you know it's history? My experience suggests oems need replacing anywhere between 25K and 50K miles. I am hoping to get much more out of the KYB's.
Let me know what you decide. If you tackle a DIY strut replacement, I might be good for a tip or two.
One last thing. Regarding your last question: back in the day, I knew of people who never replaced their shocks. Eventually, the oil that should be inside the shock (or strut) but is now outside the shock will dry and you won't see evidence of its having leaked.
