Rear Strut Loose - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 01-31-2011, 06:58 PM   #1 (permalink)
View kawazukimaha's Photo Gallery
Rear Strut Loose
I had the struts replaced about 18K ago. Rattling started 3K ago. Thought it was in the plastic bin inside the trunk. It is the strut! I think the rear seat has to come out. How does the rear seat come out? Any advice to the top of the rear strut will be greatly appreciated.
kawazukimaha is offline   Reply With Quote
Old 01-31-2011, 07:35 PM   #2 (permalink)
Gameroom cash: $223000
View buchaja's Photo Gallery
On my '03 access to the mount is behind the seat and under the rear deck. My Hane's manual said I had to remove the deck, but that wasn't true. Once you remove the seat, the mounting bolts are right there.
I had to pull up on the front of the seat bottom. Grab it down by the carpet and give it a good, sharp pull. I think there are two snap-in points, one under each seat position. Once the front is loose, pull the entire bottom out towards the front of the car. The bolts holding the back are then removed, they're at the bottom of the seat back, and then it is yanked up and off it's catches at the top.
buchaja is offline   Reply With Quote
The Following User Says Thank You to buchaja For This Useful Post:
kawazukimaha (01-31-2011)
