Engine does not rev when pressing gas pedal - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 02-03-2011, 10:40 PM   #1 (permalink)
View pizza789's Photo Gallery
Canada Engine does not rev when pressing gas pedal
I have a 2004 Sienna. I had to jump start it today (need to replace the battery). I have a "check engine" light on. Vechicle starts ok, idles fine. However, when I press the gas pedal - RPMs move up to 1100 and nothing more. No power, vechicle will move at about 2mph.
I checked for a clear air way - no problems there. I have not checked anything else as I had to leave the vechicle on the side of the road.
Ideas?
Thanks
Greg
pizza789 is offline   Reply With Quote
Old 02-04-2011, 12:11 AM   #2 (permalink)
tacosteelersman's Avatar
Gameroom cash: $170177
View tacosteelersman's Photo Gallery
Check for sensors that have fallen out of the air inlet hose. possible vaccuum leak
95.5 Tacoma 2.7 300,000
91 Corolla 1.6 180,000
96 Avalon 3.0 190,000
95 Ford Aspire 1.3 125,000
tacosteelersman is offline   Reply With Quote
Old 02-04-2011, 06:13 AM   #3 (permalink)
View whanner's Photo Gallery
low voltage may have you in limp mode. try and charge/replace the battery and have your alternator checked then you can diagnose the problem better. it may solve your problem when you fix your voltage problem. The vehicles computer expects a certain voltage for the sensors to work correctly.
whanner is offline   Reply With Quote
Old 02-04-2011, 06:33 AM   #4 (permalink)
Thanks, I'll check these items. I can charge the battery fully.
Old 02-04-2011, 11:46 PM   #5 (permalink)
I picked up a OBD2 reader today and found P2118 which appears to be a blown fuse for the accerater pedal. I will check this out tomorrow. It could be form when my son jump started the van perhaps he connected the battery wrong.
