wont always start - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 02-10-2011, 08:02 PM   #1 (permalink)
View whanner's Photo Gallery
wont always start
Just bought this 2000 Avalon and have noticed that sometimes the starter wont engage... makes no noise at all... hit the key again and starts fine. The previous owner had it in the dealer and they replaced the starter contacts but its still doing it. any suggestions?
whanner is offline   Reply With Quote
Old 02-11-2011, 12:04 PM   #2 (permalink)
View whilst's Photo Gallery
Check ignition switch(electrical), or:
Could be 'AOH' recall- upper steering bracket'.
That is what happened to my daughters' car yesterday in driveway.
No resistance to turning key. Lock rod broke.
HTH.
whilst is offline   Reply With Quote
Old 02-11-2011, 12:40 PM   #3 (permalink)
best I can tell it started before they did the recall.
Old 02-12-2011, 09:46 AM   #4 (permalink)
could this be related to the security system....if you turn the key.. no start. then turn it again and it starts. It seems to always start on the second try.
Old 02-28-2011, 12:17 PM   #5 (permalink)
View chuckoff's Photo Gallery
Could be several things, Battery, battery connections, starter solenoild contacts, neutral safety switch, ignition switch, security system, etc. Are you sure there is no sound when it will not crank? Worn starter solenoid contacts usually make a single click sound when trying to make the starter work. No sound whatsoever probably means no current is going to the starter solenoid.
chuckoff is offline   Reply With Quote
Old 02-28-2011, 12:26 PM   #6 (permalink)
It did it last night for the 1st time in a while. it was a single click. let go of the key tried again and fired right up. sounds like the contacts are on their way out hug.
Old 02-28-2011, 06:54 PM   #7 (permalink)
Pretty easy fix. Remove starter, relpace contacts and plunger. If you cannot do it yourself and talk it to a shop, do not let them tell you need a new starter.
Old 02-28-2011, 07:35 PM   #8 (permalink)
Avy
Gameroom cash: $820855
View pmesfun's Photo Gallery
+1
New contacts, plunger etc. Or just get a rebuilt Denso starter from Oreilly or similar.
I need to replace contacts soon myself.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is offline   Reply With Quote
