P0135 code - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 02-26-2011, 09:35 PM   #1 (permalink)
View jmiller59's Photo Gallery
USA P0135 code
Where exactly is the bank one sensor one located on my 2003 Toyota Avalon? I know it is near the firewall but I can't quite locate it? Anyone have any pics? Once I get it out, how do I test it to make sure it is the issue without spending over $100 for a new sensor? What is the denso sensor number for the replacement if needed? Thanks
jmiller59 is offline   Reply With Quote
Old 02-27-2011, 02:26 AM   #2 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3633850
Moved your thread over to the 2nd Gen Avalon forum so the members there can lend you a hand. You'll also want to use the forum's search feature to find any past threads discussing the P0135 trouble code.
BTW, to the nation!
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is offline   Reply With Quote
The Following User Says Thank You to TrailDust For This Useful Post:
jmiller59 (02-28-2011)
Old 02-27-2011, 10:27 AM   #3 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $281092
View csaxon's Photo Gallery
Bank1 Sensor1
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
The Following User Says Thank You to csaxon For This Useful Post:
TrailDust (02-27-2011)
Old 02-27-2011, 10:30 AM   #4 (permalink)
Denso 234-9021 Oxygen Sensor (Air and Fuel Ratio Sensor) is the part you want. Unscrew old and insert new.
Old 02-28-2011, 05:26 PM   #5 (permalink)
USA p0135
Excellent picture, made it easy to locate....Ordered the sensor today and hope to have it in by the weekend. Looks fairly simple, thanks for your help!
Old 03-05-2011, 01:56 PM   #6 (permalink)
USA p0135
Way easier that I expected! $102 Denso oem through Amazon. If you can change spark plugs, you can change the rear sensor. Took about a half hour. Car has 113k miles when it went bad, so far have not had as issue with it coding again like some others have posted.
Thanks csaxon!
Old 03-06-2011, 02:37 PM   #7 (permalink)
You're welcome.
Old 03-07-2011, 08:03 AM   #8 (permalink)
tr7driver's Avatar
View tr7driver's Photo Gallery
Thanks csaxon!
How hard was it to break it loose. I'm always afraid they will be "welded" in by heat and corrosion and I'll end up striping or breaking it off. Did you use anything like liquid wrench?
2000 Avalon XLS
2001 Highlander V6 Limited 4wd
2005 Mustang GT Convertible
1998 Avalon XLS 'RIP' (gave its life for us!)
1994 Honda Accord Wagon, 1979 Triumph TR7
tr7driver is offline   Reply With Quote
