Radio, Dome, Door lights do not work! - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 03-24-2011, 07:59 AM   #1 (permalink)
View jfields's Photo Gallery
My radio, Dome and Door lights do not work. My clock also resets everytime I turn the car off. I have checked all of the fuses and they were good. I then checked the current to all of those fuses and there is no current coming through. Is there a relay that controls this? Any Ideas?
jfields is offline   Reply With Quote
Old 03-25-2011, 12:44 PM   #2 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $281092
View csaxon's Photo Gallery
Did you check the dome fuse under the hood?
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 03-28-2011, 10:50 PM   #3 (permalink)
View maun's Photo Gallery
A typical no current problem is the ground not being correct. However, I am sorry to say that I do not know the exact location of the circuit in question. Without seeing the electrical circuit scheme, one would need to try looking for loose wires and tightening the ground connections.
maun is offline   Reply With Quote
Old 03-31-2011, 04:26 PM   #4 (permalink)
View eurobob1978's Photo Gallery
You are not going to find the mythical loose wire or poor ground. I know there are several fuses that are tied into the lighting circuit on the car. I would check every fuse both under the hood and under the dash. If everything is good, the last culprit is going to be the multiplexer unit that controls basically every input and output signal for lights, turn signals, abs lights, ect....
eurobob1978 is offline   Reply With Quote
Tags
clock, dome lights, door lights, fuses, radio
