A/C takes 15 minutes :( - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 03-31-2011, 08:31 PM   #1 (permalink)
View lmezzulo's Photo Gallery
2nd Generation A/C takes 15 minutes :(
I have a 2001 Avalon XL and is taking up to 15 minutes to get cool, any ideas or suggestions? Maybe a evac and recharge?
lmezzulo is offline   Reply With Quote
Old 03-31-2011, 11:27 PM   #2 (permalink)
View eurobob1978's Photo Gallery
anytime you need to recharge your system, that means that there is a leak. It is a closed system and the r134 should never go anywhere. I would take it to a shop and they can put a dye in the r134 and check for leaks. If there are no leaks, it would sound like a compressor is in order. Anytime the a/c system is opened up, you will want to replace the reciever/dryer(accumulator) to remove any moisture. You may have a sight glass on the line that should show you if you have a full charge. If you are low on r134 the compressor will not automatically engage and you can see the pulley free spinning until the clutch is engaged.
eurobob1978 is offline   Reply With Quote
The Following User Says Thank You to eurobob1978 For This Useful Post:
lmezzulo (04-01-2011)
