2001 Steering & alignment - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 04-17-2011, 10:11 AM   #1 (permalink)
View selpaw's Photo Gallery
My 2001 w/ 188000 miles has a steering quirk. After I do a 90 degree right turn, the car will have a tendency to veer to the right. With a 90 degree left turn it will veer to the left. If I drive on a straight road for several miles it will eventually run straight. At that point it drives great. Any answers
selpaw is offline   Reply With Quote
Old 04-17-2011, 03:26 PM   #2 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3633850
Check with your mechanic, but I think it could be an issue commonly called "memory steer," which is when the steering wheel and wheels want to return to a position other than center. This may cause a steering pull or drift to one side after turning. Some of the causes could be misalignment or improper installation of tie rod ends, an unbalanced power assist, binding in the ball joints, binding in upper strut mounts, or maybe binding in the steering linkage. Again, unless you're comfortable working on steering issues I'd consult your mechanic.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is offline   Reply With Quote
Old 04-17-2011, 04:59 PM   #3 (permalink)
Gameroom cash: $223000
View buchaja's Photo Gallery
I have the exact same condition but pulling in the opposite direction in my '03.
My alignment is good. And, I have less than 35k miles on the car. This is a known problem, with TSB issued. I cannot find the TSB related to our vehicles, but a recent internet search revealed one for the later model Tacoma.
I posted about it earlier but didn't get any replies, so I guess it's not too common.
If it helps, I also have new struts, strut mounts, and tires. Please post if anyone resolves - or has resolved - this issue.
buchaja is offline   Reply With Quote
Old 04-26-2011, 02:49 PM   #4 (permalink)
View fourwheeler's Photo Gallery
I had this issue once and it was resolved by replacing the front strut mounts. The strut mount bearings were bad and would not allow the car to return to center after turning. With you just replacing your strut mounts I'm at a loss for suggestions.
fourwheeler is offline   Reply With Quote
Old 05-19-2011, 06:59 AM   #5 (permalink)
Wink 2001 Steering & Alignment
As it turned out, my problems were caused by new, but defective front strut mounts. Once new ones were installed problems went away.
Tags
alignment, steering
