I know the feeling of changing the jammed fuel filter. I have a 96 with 150k on it. I recently had to change all my fuel lines and brake lines going to the rear due to rust on them and I couldn't split the line on the lower side of the filter. I ended up having to cut the line out with the filter on top. Anyways............
I know you said the plugs were just replaced, how about the wires? They get hot and after awhile, they get weak too. MAF dirty? Vacuum leaks? Dirty throttle body? lots of little things...check the easy stuff first.
Pull a front plug and see how they look first. It'll give you an indication of what the other 5 look like.
"Fools", said I, "You do not know, silence like a cancer grows.
Hear my words that I might teach you. Take my arms that I might reach you"
But my words, like silent raindrops fell, and echoed, in the wells of silence.....
Jason Johnston
Toyota/Scion of Des Moines
(800)342-7045
