disable daytime running lights - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 05-18-2011, 10:00 PM   #1 (permalink)
View fadesemall's Photo Gallery
does anyone know what color is the daytime running light wire in the body ecu on a 2000 avalon ? i want to put in hid's but i dont know what wire to cut and ground . they are not labled .
fadesemall is offline   Reply With Quote
Old 05-18-2011, 10:46 PM   #2 (permalink)
KoG506's Avatar
View KoG506's Photo Gallery
No need to cut wires to disable DRL. There are fuse(s) not sure exactly where but check the fuse boxes under the hood (should have labels under fuse box top) and driver side near hood opener. just pull it out and DRL is disabled.
My '00 Headlight Restoration tutorial with pics! Check it out ------> http://www.toyotanation.com/forum/sh...d.php?t=375075
KoG506 is offline   Reply With Quote
Old 05-19-2011, 06:37 AM   #3 (permalink)
I was told you can still run into problems by just removing the fuse . Headlights flickering ect. im putting in a 100000k HID kit . Are you sure that will work lol . Im just nervous . I dont wanna hurt my baby lol .
Old 05-20-2011, 09:53 PM   #4 (permalink)
1MZFE VVT-i Dual Throttle
Gameroom cash: $127700
View MCX20-XLS's Photo Gallery
There may be some related info on this DIY job over at Solaraguy. Search DRL, there's even a thread for independent fog light mod. I curious to see if they are the exact same on the Avalon.
01' Avalon XLS
My build thread - http://www.toyotanation.com/forum/sh...d.php?t=370845
For Sale Thread - http://www.toyotanation.com/forum/sh...d.php?t=389868
MCX20-XLS is offline   Reply With Quote
Old 05-21-2011, 09:26 AM   #5 (permalink)
KoG506's Avatar
I highly doubt you will hurt your Avy, as long as it have the relay harness. I don't have HID in my High beam. I just installed 8000K HID in my fog yesterday and never have ANY problem. Same for my low beams(have relay harness also), had it for almost 2 year and no problem ever since i bought it.
but I highly doubt you will run into any problem because you are only disabling the DRL. The fuse for DRL is in fuse box next to battery. its the "7.5" fuse.
