Originally Posted by moonroof
Folks, just wanted to bring this issue to a closure.
Unfortunately, my hack did not last long. I can hear the distortion at low frequencies again.
Next up, I am going to look for one of those kits with the circular membrane that is used to stick from the diaphragm to the metal frame.
When I do that (not sure when though), I will open another thread and post how it went.
Thought I would update you folks on the current status and my findings regarding this problem.
First, my "hack" I described above actually did work. I examined the speaker again a some days ago and noticed that where I had glued it back, it was still fine, but the foam had torn at other places now.
I had ordered a pair of foams for 8" speakers from ebay (for around $4.75 + postage = $7 or so). I refoamed my speaker earlier today and installed it back. Sounds a bit different at present. But as I understand it, after a little use as the new foam get more flexible, the sounds should come back to near the original. In any case, the sound cannot be worse than it was with damaged foam.
One final observation. The old foam was fine where it was glued to the surround of the speaker, but it had disintegrated where it was glued to the outer metal frame. That is also the place where the plastic bezel with a mesh in it is screwed on top of the speaker (for protection?). The pressure of that bezel probably seems to have helped damage the original foam.
Thanks.
