Power door lock problem - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 06-14-2011, 06:54 PM   #1 (permalink)
View dekman's Photo Gallery
USA Power door lock problem
2000 Avalon xls
I have developed a problem with my power door locks. It happened after i cleaned the car interior floor and seats, but don't know if this is related to the problem which has Strange symptoms:
If my ignition key is in the on position not (ACC) all door locks work properly from the driver door control switch. The remotes do not (I believe that is normal when the ignition key is on.) When I turn the key to the off position and remove the key all the door locks continue to work properly from the driver door central control switch as well as the remote transmitters. Except they only work for about 2-4 seconds then nothing works. This includes the trunk release. It's almost like they are on a some timer that turns off. I don't believe it is a programming problem. Anyone out there that has experianced this problem or that knows where i should look. I dont have a schematic diagram so am at a loss as to what it might be.
dekman is offline   Reply With Quote
Old 06-15-2011, 08:56 AM   #2 (permalink)
View bobflood's Photo Gallery
Originally Posted by dekman View Post
2000 Avalon xls
Don't know about this specific problem, but see below for source for schematics:
Auto - Online Repair Info
http://search.ebscohost.com/
PW: rebsco
Follow prompts down to Wiring Diagrams
2002 Avalon XLS; Black with grey interior; no mods; 2nd owner; 165K+ miles.
bobflood is offline   Reply With Quote
Old 06-15-2011, 07:36 PM   #3 (permalink)
Thank you
Many thanks for the help getting the schematic diagram for the locks. I should be able to trace the problem down with that.
