Originally Posted by KoG506
So there is one on the front exhaust manifold. 2nd is the one after the CAT/exhaust pipe(under car) and 3 is behind the engine block. below the rear spark plugs
Just to be technically correct: There are two "Sensor 1s" - one for each bank of cylinders before the catalytic converter. The one for "bank 2" is at the front of the engine bay; the one for "bank 1" is at the rear of the engine bay; each is in its respective exhaust manifold ahead of the cat. The Bank 1 Sensor 1 is hard to see, as the exhaust manifold is right up close to the firewall. The rear sensor, behind the cat, is usually identified as "Bank 1, Sensor 2" even though it technically serves both banks. Sensor 1 is called an "Air/Fuel Sensor" instead of an O2 Sensor (also sometimes called a 'Wideband O2 Sensor") but it does the same thing.
