2000 Avalon whining while traveling at high speeds - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 08-06-2011, 09:46 AM   #1 (permalink)
View gatordrew84's Photo Gallery
Unhappy 2000 Avalon whining while traveling at high speeds
I just purchased a 2000 Avalon with 174k miles. When I test drove the car I didn't take it on the highway, so I never noticed this sound before. However, last night I took it on I-75 for the first time and I started to hear this whining noise. At first it would cut in and out, but after going 75-80+ mph, the whining noise would be consistent and would continue to get louder. I originally thought the sunroof's wind deflector was causing the issues (as it sounded like air was being pushed in between the car and the deflector) but after removing it didn't help. My friend said it sounded like it was coming from the front of the car, so we took a video to share with you and, if necessary, Toyota. I can deal with a lot of things, but this sound becomes incredibly annoying so I'll have to figure it out quickly.
Here is the link to the You Tube video:
You help & guidance is much appreciated!
Thanks,
Andrew
gatordrew84 is offline   Reply With Quote
Old 08-06-2011, 02:01 PM   #2 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3633850
Dayum! Never heard anything like that before. Hopefully one of the other owners will be able to help you out.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is offline   Reply With Quote
Old 08-09-2011, 02:44 PM   #3 (permalink)
View ChiTDI's Photo Gallery
After you drive it, get underneath and smell. Becareful of not burning yourself, that noise is coming from something rubbing. Check behind the wheels, brake rotors and dust shields, wheel speed sensors, exhaust shields, alternator windings, ...
Did you have any front end work done? Like new wheel bearings or newly rotated tires?
ChiTDI is offline   Reply With Quote
Old 08-13-2011, 11:04 AM   #4 (permalink)
KoG506's Avatar
View KoG506's Photo Gallery
Damn!
Check to see if all the belts are aligned. also check belt to see any burn/rubbing.
Jack up the front of car and put jack stand to hold up car.(Hood open) then Put car in D and drive to 80MPH (Be careful!) Also add big fans blow air at front of the car while accelerating. and find out where the noise is coming from.
Be careful and goodluck! update us if you find out what caused the noise
My '00 Headlight Restoration tutorial with pics! Check it out ------> http://www.toyotanation.com/forum/sh...d.php?t=375075
KoG506 is offline   Reply With Quote
Old 08-27-2011, 05:06 PM   #5 (permalink)
View padutchguy's Photo Gallery
Jesus, you'd best be careful with that. Sounds dangerous. Mine is whisper quiet. Does sound like rubbing but you're going pretty fast and the engine at 3000 rpms which is more that mine is usually at at highway speeds, so it could be caused by wind noise too.
padutchguy is offline   Reply With Quote
Old 08-27-2011, 05:11 PM   #6 (permalink)
nitronate33's Avatar
View nitronate33's Photo Gallery
that sounds like a shot wheel bearing, to me anyway.
2005 Toyota Solara SE 2.4L
2004 Subaru Impreza WRX 2.0L
2011 Ford Mustang Shelby GT500 5.4L
nitronate33 is offline   Reply With Quote
Old 08-27-2011, 05:41 PM   #7 (permalink)
View jk7k2b's Photo Gallery
Last time I heard anything like that, it turned out to be a bad AC clutch/bearing. Remove the AC belt and try again.
HTH,
John
jk7k2b is offline   Reply With Quote
Tags
whining noise
