Some of the more experienced DIYers and Techs may have more of a solid input, but from what I read in the repair manual, the P0330 is more likely a loose knock sensor wire, and the P1135 is an air fuel ratio sensor. You may want to check that knock sensor wire, although if bad it is under the intake manifold and if you get that far, should just replace it, and maybe the two knock sensors themselvs.
On the P1135, sounds more likely than not that you'll have to replace that ari fuel ratio sensor. If you do and decide to go OEM, I do sell to TN members for 30% off MSRP and only charge actual shipping costs plus $2.00 for materials, and etc.
Good luck and hope this information proves to be beneficial.
