2nd Gen ignition/steering column
Hello All,
My name is Tony, with a 2001 Toyota Avalon and i have a couple questions for anyone out there that can help me with this problem. Apparently it seems that i may have to replace the ignition switch housing assembly, because the tumbler inside of the housing unit broke off (the piece thats connected to the ignition switch itself). Well my question is, how do remove the ignition switch bracket/upper support housing assembly from the steering column without replacing the whole steering column? How do you remove the two upper support bolts.
Reason: forgot to include some info.
