Toyota recommends coolant hose replacement every 6 yrs which averages out to the 90,000 mile service. My sons 99 Camry had 128000 miles using Toyota red and distilled water. I ordered a complete set of hoses from Toyotapartsman. As I removed the hoses I was amazed at how good they looked inside and showed no physical weakness on the exterior.
If I were you I'd check each hose for soft spots or deterioration. Then I'd drain some coolant and remove an upper hose to check interior condition for severe scaling.
Vacuum hoses crack and split sometimes unnoticed.
